BassScratcher
- Joined
- Apr 29, 2002
- 43
I have a 93 200 Mariner Magnum EFI. When loading the boat, I usually trim up a little and give it the gas to push it up on the trailer. The last couple of outings, I noticed that when I give it gas, the motor will drop down (the trim not holding up). After the first time this happened, I noticed that while running down the lake, the trim guage will drop a little and I have to keep trimming up. The weight of the motor alone is not enough to force it to bleed down, but I do see the problem under a load. What are my options for getting this fixed? If I have to replace the entire assembly, what are your opinions on rebuilt kits? Is it worth the money or should I buy new?
