tilt/trim bushings
challenger
Does anyone know if you can get just the bushings for the pivot pins that support the hydraulic cylinders for the tilt and trim? I know you can buy the kit that includes the pin,bushibgs and washer but I just need the plastic bushings. Thanks Shawn Forgot to mention this is on a 1995 maxum with a 4.3 motor and an alpha one drive
Don S
Re: tilt/trim bushings
Yes, you can get just the bushing. Item 11<br />PN 23-815950 1<br /><br />
challenger
thank you for your answer. Do you know if I can get these at any marine supply shop? Appreciate all your help Shawn Mahoney
Don S
I don't know about ALL marine supply stores, but IF they are a Mercruiser dealer they can order them for you if they don't have them in stock.
challenger
thanks for the info. Its my first boat and I like to do things myself. I will check into these tomorrow. Shawn
lrlima
If you cnt find it at a local shop, check dougrussell.com They should have those.
