Re: Tilt/Trim connections for 1989 johnson 60hp
Yes, the up/down keys on the engine work as long there is 12V from the battery. Mine were corroded when I got the engine. So I cut the key housing apart with a sharp knife, cleaned/greased the contacts and glued it together with 2-component epoxy glue. Still works and you can't see anything when the keys are mounted.
The keys should contact red <=> blue and red <=> green.
