tilt trim fluid level
novotm
NathanY
Re: tilt trim fluid level
Is that the one with the pump and resevoir that mounts inside the boat and has the 4 hoses that go to the motor? If so then you need to fill it when the motor is down.
novotm
yep. Mounts inside the boat with four hoses going to the outboard. Thanks.
