Tilt/Trim Fluid? What to use?
Singing Boat Guy
I need to fill up my trim / tilt reservoir after repairing my pump motor. Does anyone know what fluid I need to use? I have a 91 Suzuki DT225. I see that suzuki makes their own fluid, but I will never be able to find that in my neck of the woods, so I am looking for an alternative.
rodbolt
Re: Tilt/Trim Fluid? What to use?
dexronIII ATF works well and is the called for alternate fluid.
bgbass.1
go to a walmart or napa they have trim & tilt oil you can use atf but from what I understand there is additives that will eat seals after awhile
Ray Neudecker
Not sure where you heard that, but I haven't seen it to be the case.
bgbass.1
I was whatching them installing a trim unit and the factory tech. said you shouldnt use atf except in a pinch. he also said any brand trim oil will be ok seeind only a couple companies make it just different labels
Singing Boat Guy
Thanks for the help everyone. I ended up using the Dexron III for now, as I needed to get this boat tested to ensure that it worked after all the problems and work I had done to it. I will replace the fluid once I come across the right stuff.
