Hope everyone is enjoying Memorial Day. I fixed
(Oh happy day) my tilt/trim leaking down problem with a $.39 O-ring from NAPA. When I removed the check valve from the motor SOME of the fluid leaked out of course. The fluid was almost clear. My question is do I refill with dextron II like I have seen posted or hyd. jack oil like the NAPA guy suggested or I read while searching a few minutes ago that someone used 10w30 in a Force? This is a '87 Force 125. If the fluid in there now is not dextron will it hurt to mix fluids, if so how do I drain all the fluid out to start over?<br />Thanks
