I pulled my engine and Y pipe today to diagnose what I thought was a cracked Y pipe which was letting water into the boat up to the level of the bottom of the pipe. The pipe looks perfect, still nicely painted black, no signs of corrosion, cracks, holes, etc. The O ring was still intact and the mating surfaces were all clean. The only thing that is down there at that level is where the tilt/trim hoses pass through to the manifold. Has anyone ever had an issue with that manifold gasket leaking and letting water into the boat? I replaced all the bellows and shift cable grommet last year with no change, so I'm running out of things to look at.. nonvisible signs of issues with the transom in that location, fiberglass was all still intact and no signs of leaks or corrosion around that area.
