Tilt/Trim help
waterdawg69
my tilt/trim goes up great, but when it goes down it stops half way, and will not go no futher. thanks for any help. its a 160hp merc
dgopetactical
Re: Tilt/Trim help
does it stop in the same place every time? does the pump shut off or start grunting when it gets to that point?
Re: Tilt/Trim help
Ayuh,.......
Does the Pump Stop,.... Or the Outdrive Stops...??..??.....
How long has it been since the pivot points have been Greased,..??..??..??....
waterdawg69
Re: Tilt/Trim help
the outdrive stops, not the pump the pump is louder going up the down thats all no other diff noises. when the outdrive stops half way down, then i have to apply allittle pressure to the drive to get it down the rest of the way.
waterdawg69
Re: Tilt/Trim help
well it has been greased but still does it, anything else it might be?
Don S
Re: Tilt/Trim help
Disconnect the cylinders from the drive and see if one of them is binding.
waterdawg69
Re: Tilt/Trim help
would a really small fluid leak hurt it any where the hose goes to cylinder make this happen?
Don S
Re: Tilt/Trim help
The leak itself wouldn't cause it, but low fluid level in the pump might.
waterdawg69
Re: Tilt/Trim help
could itbe air? in the cylinders,because i have never open the vent screw when filling
Don S
Re: Tilt/Trim help
Why don't you go try it?
