Tilt/Trim Hydraulic Pump Problems-Need Help
Pessemist
I have a problem with tilt/trim on a 1984 115hp V4 evinrude outboard.
The tilt won't go up and down. I believe there is air trapped in the system as I opened the bypass valve and air shot out prior to some fluid.
Filled it up. Motor runs strong.
I thought these trim assemblies were self-bleeding but I think that is not the case.
Is there a procedure for these tilt/trims to bleed the air out?
thanks
doug
ezeke
Re: Tilt/Trim Hydraulic Pump Problems-Need Help
Steps:
Boat on level ground, make sure that the manual release valve is closed and torqued to specs;
Raise the motor and support it;
Open the fill plug, add fluid until it runs out, replace the plug and tighten;
Release the support, then cycle the motor up and down several times;
Repeat entire process until no more fluid can be added.
You will need to manually add whatever help is needed to move the motor while cycling up and down. .
