Re: tilt/trim info pleeeaassseee?
Look at the side lower portion of the starboard transom bracket. There should be a hole there that is an access port to the manual release valve. Back that valve out two turns only, no more than two turns.
Lift the engine to it's extreme tilted up position and lock it there.
On the starboard back portion of the PTT assembly, you'll see a large slotted screw. This is the fill plug hole for the PTT fluid. Remove it and be carefull not to lose the sealing O Ring in back of it.
Fill the reservoir with the proper PTT fluid. Reinstall the fill screw and O ring, then tighten the manual release valve. The unit is self bleeding so you don'e need to bother with that aspect of the job.
You may need to repeat the tilt up and fill procedure depending on whether the unit is completely out of fluid, etc...... that is, if lack of fluid is your problem. Let us know what you find.
