Re: Tilt & Trim leak
There are 2 parts to the seal glands. The outer seal you see is the wiper seal which simply cleans the piston before the rod seal. The rod seal is the one you are concerned with and is leaking. The rod seal actually retains the fluid.
I took my seal glands to a hydraulic shop and they replaced the seals for me. The rod seal can be a little tricky to install. Make sure you install the rod seal in the correct direction. The lip should be on the bottom.
Also, the rod seal they pulled out was a very, how might I say this...nonrobust. They installed a much sturdier seal.
Make sure your piston doesn't have any burrs or nicks on it as this will reduce the seal life. Take your fingernail and run it up and down the piston. If your nail catches a nick or burr, it needs to be lightly sanded out with 1200 grit paper.
One final thing, my piston did not have a lead in chamfer to assist in the installation of the seal. The bottom portion of the rod is very sharp and can shear off a portion of the new seal, making it useless. Don't ask me how I know. Again, take some sandpaper and know the edge off to assist the seal as it can be tricky to get it started.
The brown seal is the weak OEM seal.
By the way if you have any more questions let ,me know. I have become way too intimate with a 91' Evinrude 48 tilt trim unit over the past 3 weeks.
