Tilt Trim motor 1988 155 hp
jayp0209
what is the easiest way to get this tilt trim motor off... i can reach the first 2 philps head screw... and i cant get to the back one...
DHPMARINE
Re: Tilt Trim motor 1988 155 hp
I pull the whole unit out and put it in a vise.Once the trim motor is off,cover everything so dirt doesn't get into the oil system.
DHP
jayp0209
my issue is trying to get the unit out... i have all 6 bolts taken off the unit... ( 3 on each side) can it wont swing out
DHP
mikesea
on some engines you need to pull one of the eng.brackets off.Usually port is easyist
