Tilt Trim Mystery
dragon2161
Tilt/Trim was working properly until I hit a sandbar with the motor at a down position. The Tilt/Trim still operates as normal at a halt, but will only trim high enough just prior to plaining the boat before it drops back to the down position without my control. There are no visible leak on any of the cylinders and or decrease on the fluid level. Any advice is greatly appreciated.........HELP :confused: <br /><br />OMC 1.6 Seadrive
rwcreigh1
Re: Tilt Trim Mystery
this is in the wrong forum.they will be moving it.
Chris1956
Roland, Tilt/Trim cylinders have a piston seal (same function as piston rings in an engine). if this seal is bad, the motor will trim down when power is applied. They may sell replacement seals, depending on the type of motor.
waterone1@aol.com
Have you tried raising and lowering the drive all the way a few times ? (note: do not do this while engine is running).
Mod2
Moving to Johnson/Evinrude repair forum.
