Re: Tilt trim new motor replacement question
make sure to use correct length of driveshaft.
you are missing the anode ground strap. your motor will not last nearly as long without it. mercury P/N 88238A15
do not run trim motor with release valve not tightened. you can damage trim pump if you do.
fill, run up and down, check, fill, run up and down, over and over until fluid is just at bottom of filler hole when fully raised.
