tilt/ trim not working need advise off volvo penta
sdexcalibur
OK, 2 weeks ago the power trim worked no problem up down again no problem, Today I try it and nothing, We troubleshot a few things, first took off the motor and hooked it directlt to the battery,Motor worked fine, Then hooked it motor back on and hook the connectors directly to the battery, Trim went up and down as we reversed the wires.
So I thought the relays, Went out and bought 2 new ones, as I took each wire off I connected it to the new one, So I know the wires are right, I tried it after the new relays and nothing still, NOw their is a pc, that each set of relays hook up to Could this be bad????
I searched around and found the 30A fuse was blown, I replaced it with a 40A because that's all they had at the store and it popped instantly, Pretty much out of ideas, I have 2 switches one on the front consoul other is a remote on the stern, Both do nothing,
Steve
Don S
Re: tilt/ trim not working need advise off volvo penta
I've asked this half a dozen times today, What YEAR, model drive, model engine, Serial numbers anything Just like in automotive there are big differences in models between 1960 and 2008
jerryjerry05
More info please. What year/motor/drive and anything you can think of.Jerry
sdexcalibur
sorry guys it's off a 1983 4 cyc, 120 hp, 270 outdrive
