Tilt & Trim -OIL ??
cupper_3
I have a 1987 2 wire model tilt and trim i just purchased from ebay.It was shipped with no oil .will the supertech oil from walmart work or do i kneed something else?? It says power tilt and trim on it . Thanks :rolleyes:
roscoe
Re: Tilt & Trim -OIL ??
My 1995 Force tilt/trim unit ( and many others)calls for straight 30 weight motor oil. Some called for power steering fluid. It is my understanding that these Force t/t units will work with either fluid.<br /><br />I would try to determine what type of fluid was in the unit, and use the same to avoid mixxing fluids. This shouldn't be too hard as the oil will look like oil, and the power steer fluid would be much thinner.
