Hi everyone,<br /><br />I have a question regarding the trim system for an Alpha 1 outdrive, Mercruiser 470 engine, 1984.<br /><br />Trim stopped working at some point, so I got a new armature (brushes were basically gone and their wires toast, inside of armature looked bad). <br /><br />Then, put it back in place, and I wire the blue and green wires (big one from trim motor) directly to a good battery positive, and make sure the trim unit is properly grounded so as to bypass all wiring, switches, solenoids/relays, etc.<br /><br />Now, trimming one way (emberassing, but I don't remember which one!!
) goes smoothly, so I guess that's the pressure release direction.<br /><br />Trimming the other way gives funny noises, inconsistent (i.e. they change), and usually overheats the thermal protection in the armature, after which a 10 second wait will give you another 2 seconds of trim
<br /><br />Brushes are good, motor is good, clean, oiled, etc. But it consistently overheats and trims badly in the one direction.<br /><br />Do these sound like classical symptoms of air in the hydraulic fluid? Focused only on electrics so far (not my boat - yet!).<br /><br />Otherwise the outdrive *will* eventually trim all the way up or down, so can I assume the hydraulic housing doesn't need a rebuild yet?
<br /><br />So, does air in the fluid cause overheating of the trim motor as well as irregular trimming and screeching noises? <br /><br />Regards and thanks!<br />Dennis
