Tilt/Trim problem
I have a 1978 Evinrude 115 model 115899C and the power tilt/trim will go up but not down. It will go up just fine but when i hit the button to make it go down it won't go. The motor makes noise like its running and wants to go down but it won't move. The only way I can get it to go down is to use the manual release. Any help with this will be greatly appreciated.
HighTrim
Re: Tilt/Trim problem
If there is nothing restricting the path of the motor, ie trail locks, then you likely have a restriction in one of the valves. I would reccomend getting yourself a factory OEM Service Manual for that if you would like to troubleshoot yourself.
mrandmrsalf
I had the same thing happen to my 77 Johnson 85HP. I ended up taking my tilt/trim motor apart and found one of the brushes had broken wires on it. I resoldered them to the brush and everything worked fine after that.
