rivertripp
- Joined
- May 5, 2010
- 41
I have a tilt trim motor for a 75 hp evinrude. The trim motor is only 1 year old, and has been flawless during all my duck hunting and fishing trips. I went teal hunting today and the motor ran great and the trim motor worked perfectly. Although when I got home I went to tilt the motor up so I could get the transom saver off and the motor wouldn't tilt upward at all. However when I pushed the down button the motor kicked on just fine and wanted to go down (if the transom saver weren't in the way it would have moved down). Not sure what is going on, no visible leaks coming from the resevoir tank, all wires seem to be connected upon visual inspection, and when the up button is pushed not even a click sounds happens as if the fuse is blown. So any suggestions from anyone out there????
