Ok took boat out yesterday tilt work fine when put in water then when I went to trailer out of water couldn't get outdrive to trim up. when I bought boat someone had already put one of the univeral trim switched in and disabled the the original one on the throttle. when I hit the button the trim motor just clicks both up and down. Looking at other post on here but is there a way to jump across the solenoid to get it up just to see if its the solenois and be good to know if this happens while im out at the lake lucky i was at the lake behind my house so I didnt have to tow anywhere.
Thank You,
1992 renker 21' cuddy
mercruiser 4.3l 2bbl
alpha one out drive
sorry I dont have serial number to trim pump.
xwind
Thank You,
alpha one out drive
xwind
