After a lot of looking around it looks like what I thought was a 1993 motor is actually seems to be a 1982 motor (Mercury 40 HP, 4 Cylinder, 2-stroke, serial: 06138161) on a 1993 pontoon.
Anyway I'm having a problem with the trim, I managed to find the release screw so that I could lift it into the up position. After re-tightening the screw and pressing the down switch on the side of the motor, it will go back down. But it won't go up. I can hear the pump motor working, but it will not go up. I opened the oil filler nut on the front and some oil came out (the boat is currently on a fairly awkward slope backwards, so I'll have to figure out a way to fill it again and what oil to use).
I am also wondering what the 5th screw is for on the top centre-left of the pump, it is raised and must have some special purpose (see attached photo).
Any hints or ideas on what could be the problem would be most welcome.
