projectlarson
- Joined
- Apr 25, 2011
- 20
i have a 90 larson with a quicksilver commander contol. i bought this as a project a month ago and am at the end of it. the up solenoid wasn't working so i changed it out tonight but the switchs on the controller are not working. i can hot wire the solenoids and make them go up and down. but the actual switches are dead. i also noticed this wiring problem on the outdrive. i could not find a wiring diagram for these two item and i even downloaded the manual 6. can someone tell me what this is and where the missing wire goes. i have to get back in the and clean all those corroded parts but want it all to work correctly at this point. i put my voltage meter on the terminals to see if the corrosion was the problem but that isn't the case. thanks for the help
