tilt trim unit. id three plugs.
hughybabes
Johnson 50 hp. 2 stroke. 2001 model.
Checking level on tilt trim unit; damaged O ring when replacing. Noticed fluid on ground next day. Tilt would not lift motor without my assistance. I will try to attach photos but there are three plugs......top one; fill hole.....one directly below,I assume is drain plug.....Third one to the bottom left ?? has a circlip and a screw?? Can someone id this and tell me whether it is missing a cover or something...
Vic.S
Re: tilt trim unit. id three plugs.
If you go to the BRP PARTS WEBSITE and fid your engine by make, year, hp and model number then go to the "Power tilt and trim" page you will get a diagram of the whole thing with all the parts identified.
hughybabes
Thankyou very much. My exact Model number , BJ50VLSi, does not rate a mention but I have seen the trim tilt unit on very similar models.
