tilt trim wire whats up ?????
mikesea
Re: tilt trim wire whats up ?????
are you sure the motor works?if so,have you tested the switch?otherwise I see no reason as long as your connections are good and tight,
mitchsboat11
the switch should be fine cuz i here the silonoid clicking so it most be good im guessing the motor must be shot just anuther head eck to this f'ed off projet of mine fun fun fun well thanks guys
Bob_VT
I would check the motor.
Connect the ground and one other wire from the motor..... the tilt motor "should" operate in one direction or another.
Now check the other wire......
See if the motor is operating in both directions.
The switch is easy to diagnose with an ohm meter.
What motor is this on? Year?
RRitt
its a 1973 johnson 135 ive tryed this heres a pic of what ive done and the motor did not work at all just sparked really bad and almost welded it self to the + on the batry
http://i898.photobucket.com/albums/ac190/mitchthepiercer111/whatsgongon.jpg
you were telling the motor to spin in both directions at same time. nothing + arc welding is what it should do when wired like that. If you hold it that way long enough you may even get to see flames shoot out of it.
mitchsboat11
no i tested them at differant times not at the ame time red wire first and then blue wire after
RRitt
then either your windings have worn through their insulation of the cover bolt is shorting out against the center tap. Either way, it's a rebuild/replace scenario.
mitchsboat11
ya thanks rr dont really need it to make the boat run so thats the last thing on my list now hahah f-ing criagslist find go bad what are you going to do
Bob_VT
Well a trim motor rebuild kit is available but it is a PITA on the older ones.
Ebay has many trim motors (china trim motors) and all you need is a 3 wire motor
mitchsboat11
ya i found some on ebay for like 45 bucks witch is not bad at all but i need to by a new starter first cuz well the boat needs one to work and that is what i need to spend my money on also found one on ebay that is a china one for like 70 bucks brand new so just saving my pennys
