1971 Chrysler 55 HP 557 HC. Tilt/trim motor had broken wires, and I took it apart last year. I cannot remember which wires go where. There are three wires going into motor: blue, green, black. I believe black goes to one brush. Blue is still attached and goes down and into one of the two semicircular wire nests on the side of the housing. I assume green goes to the other wire coming up from the other semicircular wire nest. There is a bridge between the two nests, and it has a wire coming off of it. This has to go to the other 'positive' brush, but there is evidence of two connections to the 'positive' brush. There is some rust on the brush plate, and it is hard to see clearly. Am I close?
