jdlloyd_iboat
- Joined
- Jan 15, 2006
- 52
I have not used my bass boat all season for reasons I will not reveal. :>( I occasionally check the tilt/trim to see if it is still working. No problem until this week-end! Batteries are on a maintenance charger and are fully charged. The relays both work (click) and voltage is getting to the harness in both up and down modes on switch. Tilt motor makes no sound and I was unable to fully investigate. Some background: Boat has been submerged in fresh water for a day or two in each of the last two years. I rebuilt the starter last year when it finally gave up the ghost but essentially the motor was recovered and worked fine after both submergences (transom was overtopped and the bilge pump was overhelmed at dock in a Nor'easter both times!). Anyway, the motor is now in a vertical attitude on the trailer. I left my repair manual at the lake. What might be the problem? Do I need to remove the tilt motor to test it? Can it be disassembled? Can it be rebuilt? Would dunking in the water be a possible cause for this condition after two annual dousings and sitting idle for almost a year? What else might I be on the lookout for? By the way, the trim/tilt sensor or gauge failed after the first dunking and I chose not to fix it. Thanks for the advice. Jim
