tilt/trim
clasavi
my switch "up" button does not work on the throttle stick however the "down" button does. when I press the trailer button on the stick, the motor trims up. can anyone suggest what i need to do to figure out what's wrong with it.
Fishermark
Re: tilt/trim
It would help to know more specifically what you are working on.... but my guess would be a faulty trim limit switch. or corroded wires.
fngboater
Re: tilt/trim
i second that one...mine does the same.my trim limit switch is bad.
achris
More fish than mountain goat
Re: tilt/trim
Quick fix is to link out the limit switch. If you do that, be aware that you can tilt the drive UP all the way on the UP switch.
