Tilt Tube& Mercury outboard serial number question
1z31
The steering ram on my Mercury 115 hp 2 stroke outboard is frozen inside the tilt tube. I'm trying to determine what year the outboard is using the 7 digit serial number (6093650) in order to purchase an after market steering package including a stainless steel tilt tube. Can anyone help figuring out what year my Merc outboard is and recommend a company that I can purchase a steering package from.
Thank you in advance for any help/advice (I tried uploading photos but kept getting an error message)
Ed
Charlie61
Re: Tilt Tube& Mercury outboard serial number question
115hp inline 6 ser 6263656 is a 1983 you may want to try maxrule.com or wholesale maine.com
1z31
Thank you sir for the info. I will check the websites.
Ed
Chris1956
Ed, Put a pipe wrench on that cable end and rock it back and forth. If it moves at all, put some penetrating oil on it and continue to rock and lube. Eventually it will work loose.
Heat will also loosen the steering cable end.
