hello all, replaced tilt tube and had a rough time getting it out ,one side came out ok but had to take port side stern bracket off with tilt tube stuck in it and had to have it presed out at a local marine shop. My question is when eng is tilted up past the brackets ,how much play should there be between the tilt tube and the swivel bracket,and should there be play between the tilt tube and stern bracket .or should it be tight. it moves when you shake the eng ,just a bit.<br /> ps this is a great web site, i have learned a lot just reading the posts, and over the winter i will be making repairs, so the spring will go well, <br /> THANKS<br /> <br /><br /> MR GIBBS
