I need to replace a tilt tube on a 1990 Black Max 200. Should i release the pressure on the tilt trim unit before I remove the old tilt tube? My concern is that if its pressurized when I remove the old tilt tube it will make it hard to align the transom brackets with the pivot tube. Any advice?
Thanks
Thanks
