simplystressed
- Joined
- Mar 16, 2009
- 176
Hi all does anyone know if the tilt bracket on the 9.8 mfsa3 should be spring loaded? Its the mechanism with the side handle to latch the motor right out of the water.
It automatically locks into shallow water mode (i can see the spring on the bracket) but the full up position isn't locking into the groves.
Mine doesn't seem to be; but I checked the mechanism and the spring and two bushings are in there correctly. Had a 6hp before and it was spring loaded so not sure if this one is or if something finicky is going on.
thanks!
thanks!
