Re: Time to buy remanu engine--help
If you have an engine with all the marine accessories already and simply need a long block, I would strongly suggest buying a brand new truck crate engine from GM. The truck cam is nearly identical to a marine grind and you can simply bolt your marine externals on. You can check to make sure the freeze plugs are brass - but those are easy to change. Here's what I am talking about:
The engine pictured is sold at Jeggs for $1769.99. Here's the description and specs:
This four-bolt main block has a one-piece nodular iron crankshaft and powdered metal connecting rods with dished hypereutectic pistons for a 9.4:1 compression ratio. It features a flat tappet hydraulic camshaft and swirl port intake design. The exhaust flange is 7-bolt, and the valve covers are centerbolt. 200 horsepower rating at 4000 RPM (300 ft/lbs TQ) and includes an 8" balancer, 4-quart oil pan, timing cover, and valve covers.
Specifications
Block: Cast iron, 4-bolt main, 1-piece rear main seal
Connecting Rods: Powdered Metal Connecting Rods
Pistons: Dished Hypereutectic
Compression Ratio: 9.4:1
Oil Pump: High-Volume Oil Pump
Timing Chain: Morse link-type
Camshaft: Flat Tappet Hydraulic (Lift .382" Int/.402" Exh; Duration @ .050" 165.9? Int/174.8? Exh; Lobe Separation Angle 111.9?)
Cylinder Heads: 65.3cc chambers, 1.94"/1.50" valves, swirl port intake design (heads are not performance-oriented; intended for good bottom end torque and fuel economy; intake runner is restrictive because it has a ramp cast into the bottom of the bowl to promote high swirl)
