Ok old transom almost out and the deck comes out next. I think it's time to start ordering some supplies. I can figure out the quanity of each item just have some questions about the types of items I need. Here goes!
PAINT
Topside = Interlux brightside
1. Bottom should I do everything on the bottom with bottom coat paint? Or do I need to paint everything under the waterline with bottom coat and the rest above the water with brightside paint?
2. Is precoat good for everything? Inside boat outside the boat or do I need something different for each?
3. What fillers do I need to fix unwanted screw holes nicks dings and such?
4. Do I use brightside for inside the boat aswell?
GLASS
5. When I cut out my deck I need to do the top and bottom of the new ply with glass correct?
6. Any wood I add to the boat needs glass seat boxes, side panels etc.?
7. I'm doing the transom, deck, and some seat boxes mabey side panels. What size mats will I need?
8. If I find I need to do a hull repair will I need anything different?
9. Other than resin what other items should I have on hand? cabosil talc wood powder or dust or somehthing like that?
Plywood
10. I go to home cheapo what is the name of the plywood I need to ask for?
(Doing the transom and deck)
11. I can figure out the thickness for the transom but my deck right now is about an 1/8 of an inch resin/fiberglass deck. Should I stick with that size ply or do I need to go thicker if so how much?
I think that is it for now I'm sure I'll think of other stuff later. If you see items I may need that not mention please be sure to mention them.
Thanks for the help
My project is listed below if you want to take a look!
PAINT
GLASS
Plywood
Thanks for the help
