apritchard@Iboats.com
- Joined
- Mar 16, 2020
- 1
LAYING-UP AND
LAUNCHING GUIDE
You will find more detailed information in your engine instruction book and our do-it-yourself manuals. Or consult your authorized Volvo Penta dealer, who will be pleased to carry out your servicing and maintenance, if you do not wish to do it yourself. Certain complicated jobs are, of course, best left to an authorized dealer since they call for both specialized knowledge and special tools.
Always use Genuine Volvo Penta Parts. That way you can be confident that the parts you use will be of the right quality and fit perfectly. And make sure you have tools on board and that your on board repair kit is complete.
Remember the environment
– collect any oil, coolant, degreaser, paint, etc., and dispose of them in the proper containers.
There is an instruction manual, providing you with more detailed information, on each particular engine. The time intervals mentioned by us are only general and can vary between different engine types. The operator's manual will give you the proper intervals for your particular engine. However, entirely different intervals apply, if you use the engine for commercial purposes or in very polluted waters.
2
Choose Volvo Penta engine oil which has good inhibiting qualities and you will not need to add any special inhibiting oil for a normal winter lay-up.
A new oil filter will remove soot and metal particles from the oil and prevent unnecessary engine wear. Genuine Volvo Penta filters are tested and specially designed to suit each particular engine type.
LAUNCHING GUIDE
TIME WELL INVESTED
This guide covers most of the items to be checked and seen to on your engine and drive when laying up and launching. Although it won’t take more than a couple of hours of your time each year, your engine will run more reliably and economically and use less fuel, with less chance of unnecessary breakdowns. Life at sea will be safer.You will find more detailed information in your engine instruction book and our do-it-yourself manuals. Or consult your authorized Volvo Penta dealer, who will be pleased to carry out your servicing and maintenance, if you do not wish to do it yourself. Certain complicated jobs are, of course, best left to an authorized dealer since they call for both specialized knowledge and special tools.
2
| Oil and oil filter changes | 4 |
| Cooling system | 6 |
| Thermostat | 10 |
| Impeller | 11 |
| Cooling water hoses/Exhaust hoses | 12 |
| Drive belts | 13 |
| Fuel system | 14 |
| Air filter/Air intake silencer | 15 |
| Electrical system | 16 |
| Oil changes – drive/reverse gear | 18 |
| Drive | 20 |
| Propeller | 22 |
| Cleaning and painting | 23 |
| Ignition system | 24 |
| Ventilation | 25 |
OILAND OIL FILTER CHANGES
You should change the engine oil and oil filter after approx. 100 hours of operation, or at least once per season.Choose Volvo Penta engine oil which has good inhibiting qualities and you will not need to add any special inhibiting oil for a normal winter lay-up.
