Timer base trouble
elwilliams13
My 1991 evinrude 225 timer base is kind of stiff, Is it suppossed to move freely it is not comming back down against the idle screw when I throttle down. Was wondering if removing flywheel and a lubrication, cleaning, and inspection might help my problem? Any help would be appreciated.<br /><br /> Ernie.
rodbolt
Re: Timer base trouble
hello<br /> first check the throttle link pivot bolts. if all the linkage is free its time to remove the timer and clean the bearing surface.<br /> will be a good time to check for loose flywheel magnents while your there
elwilliams13
Thanks for the advice will do that and get back to you guys.
