Thanks, The roller for the timing cam was missing. I'm not sure if the motor was timed with the roller missing at some point as it was 2 degrees retarded with a new roller installed. 60mm from ball end to ball end was still a little retarded. I had about 5mm between the links. My service manual says 2 full turns of the link end is about 1 degree. I turned the link 3.5 turns or about 1.75 degrees more. I still need a calm day to test @ wot on the water.
