Luvmyforce
- Joined
- Feb 23, 2006
- 3
I am having a bit of difficulty in adjusting the timing on my Force. The slot on the adjusting screw faces towards the trigger assembly which makes it impossible to get to. Also, how much adjustment of the adjusting screw is neccessary to change the advancement or retarding of the timing. Also, setting timing to recommended 28* degrees BTDC is checked with engine running at proper idle speed correct?
