Thumper2442
- Joined
- Aug 25, 2007
- 15
I bought a 15 hp Johnson to upgrade my jon boat from a 9.8 Merc. The first time out it overheated. I fixed that. Then it wouldn't run right. I checked compression and one cylinder was only 60psi. I replaced the rings and have good compression on both cylinders now. Now it lacks power. I paid for a Seloc online manual so I could adjust the timing and all it told me was small engines use the point gap to adjust the timing. I already know that's wrong. I've had the flywheel off more than once, set the point gap, and still can't figure out how to set the timing. I put a timing light on it and the lines on the flywheel don't sit anywhere near something that could be mistaken for a timing mark. There is a raised part with lines and a hole in it on the back under the flywheel. Is that what the timing is set by? There's no sign of degree marks on it. I'm trying to get this thing going for the week after Labor Day. Can anyone help? Thanks.
