Timing belt change on AQ125
Peter1950
Does the heat exhanger have to come off to change the timing belt? Cam pulley looks mighty close but will it clear?
robjen1019
Re: Timing belt change on AQ125
Yes, it needs to come off. There is a belt tensioner behind that needs to be adjusted.
zbnutcase
The heat exchanger can stay bolted to the exhaust manifold; it's the coolant tank that needs to come off. 'nutcase
