Timing Cam on 1975 Johnson 70 hp
cvlngineer
Could someone please post or send me a picture of what the OEM cam and cam follower (roller) assembly is supposed to look like for this motor? I just want to make certain that I have the correct one on here.<br /><br />address is smithcharlesw at hotmail dot com<br /><br />Thanks in advance,<br /><br />cvlngineer
bowhuntrrl
Re: Timing Cam on 1975 Johnson 70 hp
Is this a trick question ??? Engine is 3 cylinder , 2 stroke, no cam !!!!<br /><br />bowhuntr
Joe Reeves
Cvlngineer..... I don't know if you received that yet. I'll scan and send it to your e-mail address.<br />---------<br /><br />Bowhuntr.... He's not speaking of a "camshaft", but rather the cam that rides against the throttle opening roller on the starboard side of the powerhead.
cvlngineer
Joe,<br /><br />Thanks very much for the picture. That is the one that is on here, so I can, at least, rule that out.<br /><br />Thanks again,<br />cvlngineer
cvlngineer
Joe,<br /><br />After looking more closely at the picture, I see a dimension given for the length of the rod that pushes the timing cam. It looks like it says the distance is 4.31/32" Does that mean 4 and 31/32 inches or 4.31 - 4.32 inches? <br /><br />I appreciate the help,<br />cvlngineer
Joe Reeves
Four and 31/32" (1/32" short of 5")
cvlngineer
Joe,<br /><br />You are a heck of a guy! Thanks for all of the information, and for taking the time to scan and send the picture.<br /><br />cvlngineer
