Timing disk "bindy" mot returning home J150vxsig 2001 looper Carb motor
rothfm
Ensign
Was habing a time with high idle. Isolating my entire linkage from remote, thru the motor...the culprit is the timing disk on top of motor....the timing advance assm. All othwr rods etc are ok.
Even took it off, slight lube to seenif would help..not really.
Book just says to ensure rotates properly, can these plastic be sanded slightly so it will rotate freely?
