Re: timing for 1989 mariner 115 6cly inline
WOT is around 25 degrees, I think, but don't want a scorched piston.
Well all the magic number can be found in the FAQ...
Set the max-advance stop to 21 degrees for "direct charge" crossflow inlines
Max advanced timing can be set by running the engine by starter ( only #1 in engine, NO fuel to carbs, FULL throttle ), timing should the be 20>21 degrees ( will be retarded to 18 degrees at WOT by the swichboxes them self ).
P.S disconnect the wires for the "idle advance module" during timing adjustment...
OR by running the engine at WOT, should the be 18 degrees max advance...
25 degrees WILL putt your pistons at BIG risk !!
And "around" are NOT a good term when timing a classic inline....
Arne Kjetil
