Timing for h comp engns w unleaded gas
SCO
I have a 73 135 hp v4. Considering that we all use unleaded and these engines were designed for unleaded, what numbers should these engines be timed for? My service manual specifies 5 degrees advance at idle(I presume idle in the water in gear at 650 rpm) and 4300 to 4600 rpm in gear at 22 degrees advance. Thanks
Dhadley
Re: Timing for h comp engns w unleaded gas
Those are good numbers, dont worry too much about the idle setting. I would recommend checking the wot timing at 5800 rpm.<br /><br />Good luck!
kglinz
Actually the big problem running unleaded fuel in older engines had to do with valves and valve guides in 4 stroke engines. Not having the lead meant less lube on the valve stems.
FlyBoyMark
Ensign
Lead was the original antiknock compound..lubricity for valves was jus a side benifit...
SCO
I've heard both ideas. Seems leaded effectively did the same as raising octane to prevent knocking, but the octane was not raised( 87 octane in those days too I think). Forktail, you ought to know the answer on this one. We need a chemist to satisfy the curiosity. What Dhadley says can be considered as gospel.
