I'm trying to resurrect (on the cheap, of course) an M2.5A from my father in law. It used to work OK, but then it went for a swim in some salt water (ughh!) and gradually stopped working. I've stripped it down to nothing and built it back up. I found that the condenser was shot, so opted for one of those "electronic ignition" modules you can throw into a lawnmower to replace the points/condenser, hoping it might do the trick. It didn't. Actually, it sort of did: the motor DID run for a few seconds with the module, but roughly. Anyhow, it gives me the confidence that I got the reed valves in properly, and the new rings on the cylinder, etc.
Anyhow, now I'm back to the points/condenser. I've gotten a replacement condenser (OK, it's not really the right part, because they're no longer available, but it's a comparable capacitance, and I'm hoping it'll do the job), but now I need to know how to set the timing.
Surely there's SOMEone out there old enough to have set the timing on an engine with points/condenser
. And MAYBE that someone has a tohatsu 2-stroke shop manual and can let me know what the right setting might be (and how you adjust it on this motor).
Profound thanks in advance.
--John
--John
