Re: Timing light question
OK, The timing decal on the flywheel is where you check the timing with the light. Set #1 cylinder to TDC, using the screwdriver. Now see how close the TDC mark on the decal is to the timing pointer or cowling timing mark. if they are not close (within 1/4 ") the outer flywheel may be installed incorrectly. If so, loosen the 8 5/16 fine thread bolts around the flywheel nut and rotate the outer flywheel only until the timing marks align. The motor should still be a TDC for cylinder #1. Now reinstall the 8 bolts. Now remove the distributor pulley cover and see if the cast arrow points to the punch hole on the flywheel. It can be a 1/2 tooth off, which is normal. If not, remove the belt and turn the pulley until it is correct, and reinstall the belt. If you have the 850 with the timing pointer(likely a 1974 model), you should make sure it is exact. I would measure the distance from the spark plug seat on the head to the top of the piston (via the plug hole), add .464 inches and then turn the flywheel CCW until the piston is .464 inches lower in the cylinder. Now the timing pointer should be adjusted to indicate .464 BTDC on the timing decal. Follow the rest of the Seloc instructions to set the idle pickup timing and Max timing.
