Muddy Rudder
- Joined
- Apr 20, 2009
- 6
hello all,
I recently purchased a boat with a 40hp evinrude vro. upon our first launch, the motor was started on land with earmuffs and starts, throttles up idles etc very well, clean and responsive. when we put the boat in the water all started and idled fine when throttling up, we could not get the boat to plane. it would die as if it was starving for fuel. So we cleaned the carbs, added new plugs etc. same problem. then i noticed a little red lever near the throttle linkage (which i suspect is some kind of timing advance lever) so when throttling up i moved this lever forward manually and the motor took off and ran very smooth until idling down. when idling down it would start bogging and breaking up so i began to readjust that red lever again to the position it was in before and it began to idle fine again. my question here is there suppose to be some kind of linkage that controls this little red lever to match it to the throttle position??
Thanks
Chris
Thanks
Chris
