Timing on 86' 35hp johnson
bayourat
motor idles fine and revs up when not under a load, but when put under a load it bogs down. I have clean the carb to make sure the jets were clean. Could the timing not be set correct if so how do you set the timing?
Harker
Re: Timing on 86' 35hp johnson
Your manual should give you the info on setting the timing.
