Timing on an 72 85hp outboard
joshrogel
I feel retarded for asking this. For some reason I don?t understand the timing on an outboard. In the manual I have basically all it says is to a way to find TDC, and put the point correctly on the flywheel. There are timing marks on the flywheel, but how to adjust to the correct setting? Everything looks keyed.
Can someone explain this to me. :)
scanman
Re: Timing on an 72 85hp outboard
This might help ya. Scroll down to post #212 & start readin. It made a world of difference in the performance of my motor! Yours has a breaker point style ignition too, unless it's been converted. Also you can search these forums for "timing" & look for a motor close to yours, but, IF timing is your problem, I'm certain this'll help.:)
http://forums.iboats.com/showthread.php?t=441949&page=9
emdsapmgr
The original factory manual has an excellent section on setting timing. Suggest you obtain one from Ken Cook Co., in Milwaukee. It's really a multi-step process and is well illustrated in the manual. First you set the timing pointer, then set the timing. You first need to adjust/verifty the timing pointer setting. You do that with a tool which is inserted in the spark plug hole. By measuring on the flywheel, you can determine if that pointer needs to be moved-you unscrew the metal pointer and move it accordingly. Once you know that adjustable pointer is set correctly, then you time the engine like a car. The airbox cover should have a decal which will show the max timing degrees for that engine-it should also be in the front pages of that service manual. You need to keep in mind that the max timing needs to be set at a high throttle postion, between 4300-4600 rpm. You can't set the max timing at idle, as the ignition system will internally creep the timing as the rpm's increase from idle-potentially resulting in too much timing and a smoked powerhead. You timer base has a sensor-no points.
joshrogel
Thanks I will look into this on my next off days. Thanks again.
Where can i get a tool that measure the pointer. The one you stick in the SP hole?
boobie
I do believe the 1972 85 hp had breaker points and they should be set correctly before setting the timing.
emdsapmgr
Boobie, you are correct the 85 hp model V4 did have dual breaker points. The 85 hp had dual breaker points, the near-identical 72 100/125 hp had a sensor. Am constanly amazed at OMC and their engineering. Go figure. Regarding the piston stop tool- ask any Bombardier dealer about part number 384887. You could make one out of an old spark plug and a bolt.
