foxtrap2452
- Joined
- Apr 19, 2010
- 4
Attempting to check the timing on my 1997 5.7LX Mercruiser engine thunderbolt V system. Connected the purple lead to ground. Put the timing light lead on plug wire #1 but unable to see any timing mark on the balancer. There is a scale on the balancer but no tab. Also I noticed that plug wire #1 is at 11 o?clock on the distributor (upper LH), where according to the manual is should be at 4 o?clock looking from the front of the engine. I revved up the engine a bit and saw the timing mark just coming up from the opposite side of the balancer. Any info on this confusion would be greatly appreciated. I replaced the spark plugs, wires, distributor, filters etc. but the engine still runs a rough. I can manage to get 31 mph at WOT at 3600 rpm (that?s a bit low according to the specs.) The boat is a 1997 Bayliner 2452 with bottom paint which might take away a few rpm I?m told.
