Olias
- Joined
- May 28, 2013
- 99
Okay folks, I am beside myself. I have tried everything I can think of (and have been suggested to do/try) and still can't get this motor to run properly. I have new coils, new points & condensers, new fuel pump, new spark plugs, have done a rebuild on the carb and I still can't get this motor (see signature) to idle properly. I'm brand new to O.B. motors but my problem "seems" to be a timing issue, possibly. I say this because I can get the motor to start (when It's cold) but the only way I can get it started and idle is at a pretty high rev/rpm. The thing is that at low RPMs the armature/ignition plate vibrates back and forth pretty violently. But if I give it gas (in neutral or in gear) the armature/ignition plate is rock solid. No vibration at all. Nice and smooth. So it makes me think that the timing is off a bit. I have the points set (at .20) to open at the middle of where its says "top" on the cam. Do I need to adjust them so the points are at .20 at the beginning of of where it says "top" maybe? I just can't get this darn thing dialed in. Any suggestions? Thanks.
-B-
-B-
